Re: Hand cranking a H
Posted by Roge WI on July 13, 2004 at 19:57:35 from (69.58.151.130):
In Reply to: Hand cranking a H posted by JimBub on July 13, 2004 at 16:14:05:
I just replaced the pin on the H I am working on now. Someone had sheared the pin off and had been using a vise-grip or pipe wrench to turn it. They had worn a groove around the shaft so I couldn't even find where the pin was. Finally used a punch in several places until I found a spot where the pin moved. As the others said, I just used a bolt (cut off the head and threads leaving about a 1/4 inch on each side) to replace the pin as a standard bolt fits tight in the hole. Roger
Post a Followup
: Re: Re: Hand cranking a H
