Re: Re: Re: Super C governor problem....
Posted by Bob on July 15, 2004 at 14:41:17 from (66.163.134.177):
In Reply to: Re: Re: Super C governor problem.... posted by Jesse on July 15, 2004 at 14:02:06:
If the spring is broken, you would loose speeds above idle, NOT idle.
Before you remove the governor (unless you've already got a by-the-book timing plan), rotate the engine until the distributor drive slot is vertical (or horizontal, if you prefer), and note it's position. DO NOT rotate the engine with the governor removed, and then when you go back to instll it, be sure the slot is in the previous orientation.
Post a Followup
: Re: Re: Re: Re: Super C governor problem....
