Re: 450 Wiring, w/o Ballast Resistor
Posted by Bob M on July 16, 2004 at 07:56:52 from (165.170.128.66):
In Reply to: 450 Wiring, w/o Ballast Resistor posted by Red Raider on July 16, 2004 at 07:31:36:
Red - Probably that extra wire leads back to an aux terminal on the starter solenoid. It’s purpose was to bypass the ballast resistor thus feeding 12 volts direct to the coil when then engine is cranking.
You can verify by putting a voltmeter or test light on the wire – it should show power only when the key is turned to the "start" position.
Anyway if that’s what it is, with an internally-ballasted coil that wire is not used. You can either tape off or remove it entirely.
Post a Followup
: Re: Re: 450 Wiring, w/o Ballast Resistor
