H carb rebuild
Posted by ellson on July 17, 2004 at 04:42:01 from (12.214.66.120):
I'm rebuilding the carb on my H and the slot on the idle metering jet is gone Any ideas on how can I remove it to replace
Post a Followup
: Re: H carb rebuild
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
