Re: 51 M heating up
Posted by James on July 17, 2004 at 13:01:50 from (64.12.116.14):
In Reply to: 51 M heating up posted by nick on July 16, 2004 at 13:21:44:
You said that you put in 6 gallons of coolant. Did you mix the coolant with water {50\50} mix. Straight coolant will make the engine over heat. Also if the carb is stopped up it can lean out the engine and over heat.
Post a Followup
: Re: Re: 51 M heating up
