Re: Farmall H Belt pulley seal
Posted by Wayne Swenson on July 17, 2004 at 14:41:50 from (66.191.70.31):
In Reply to: Farmall H Belt pulley seal posted by Rock on July 17, 2004 at 08:42:00:
My 2 sons & I just re-did 2 gearcases for their belt pulleys on their "H"s". we had them on the bench but you can just remove the driven shaft on the tractor.
Remove three capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance.
Remove the cap screw on the end of the shaft and all the parts can be pulled off.
I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is corect you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size.
I have a Case/IH dealer in town (Fergus Falls, MN) so otained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost.
Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don't mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don't ask how I found out) and will not compress the spacers under the pulley flange.
mail me if you need more info.
Post a Followup
: Re: Re: Farmall H Belt pulley seal
