IH 424 with no power!!
Posted by rockingfarmer on July 17, 2004 at 19:29:57 from (69.179.26.208):
I was wondering if anyone could help me out with a problem I have been having with my IH 424 utility. It starts and runs fine for a while but after it heats up it begins to bog down and will only run if I pull the choke all the way out. I have tried nearly everything in the owners manual to no avail (fuel lines, filters, coolant levels, cleaning the carb without taking it apart etc). I have heard that the clicking noise made when you turn the key to the on position is the fuel pump and this tractor has recently stopped making this noise. Is there any truth to this? And would it still start and run without the fuel pump working? ANy advice would be very helpful as I have hay cut waiting to be baled. Thanks
Post a Followup
: Re: IH 424 with no power!!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
