Re: IH 424 with no power!!
Posted by Haas on July 18, 2004 at 11:53:42 from (12.65.48.99):
In Reply to: IH 424 with no power!! posted by rockingfarmer on July 17, 2004 at 19:29:57:
Yes, the 424 gasoline has a fuel pump that is electric. When you turn the ignition on and before you start the engine, you should hear a clicking sound. Could be a carburetor problem, or you may have fuel pump troubles, keeping you from getting enough gas. Also, the 424 has a solenoid on the carburetor that shuts off gas to the main jet when you shut off the ignition. The purpose is to keep the engine from "dieseling" when you shut it off. If that solenoid is faulty it could be restricting gas flow too. In any event, it sounds like a gasoline supply problem or a carburetor problem.
Post a Followup
: Re: Re: IH 424 with no power!!
