460 question
Posted by Kelly C on July 19, 2004 at 19:15:37 from (63.171.43.140):
This is just bringing to the front the disc we were having about my 460 running like crud.
So far I have cleaned and checked the fuel line from the tank. I picked up a dist cap/ rotor/plugs/ wires/ points and condenser.
Old ones didnt look bad but I might as well know where I am at with it.
Took the dist off and checked the advance wheights. They look fine and move free.
Also picked up a carb kit. will be doing that.
No vac leaks found and the heat riser moves free with the spring.
Will see what happens when I get those in. I will do a comp test as soon as I find my tester.
Maybe I will get lucky and fix it. If not I cant think of any other possabilities but the Valve thing that Chad had mentioned. If it is so be it.
ANy one got the tune up specs for a 460 handy? Be a few days before the manual gets here. SO far thats happened with 2 tractors. Cant wait for the manual to start fixin.
Post a Followup
: Re: 460 question
