Re: Farmall Super C Governor install mishap...Help
Posted by parts man on July 19, 2004 at 19:53:20 from (207.179.147.131):
In Reply to: Farmall Super C Governor install mishap...Help!!!! posted by Scott Swanson on July 19, 2004 at 06:11:11:
Scott, find TDC on compression of #1 cylinder. Move your rotor button to line up with #1 plug wire. Put the distributer drive in to line up with the notch in the driving gear of the governor. This will get you close, you then need to time the distributer by loosening the clamping bolts at the base of the distibuter body, and timing to TDC. IE, roll the distributer till you get a spark at #1 plug when the engine is at TDC on #1.
Post a Followup
: Re: Re: Farmall Super C Governor install mishap...Help
