power lift on farmall H
Posted by Hank on July 20, 2004 at 12:26:45 from (162.39.133.114):
I got an old H running and had noise comming from the power lift chamber. Put oil to the full mark
and noise was louder and oil poured out the bottom plate. I pushed the lift lever all the way forward and stopped most of the noise.
My manual does not show a schemaic of the lif pump. How is it connected to the drive shaft?
can tractor be used with pump off?
Post a Followup
: Re: power lift on farmall H
