Re: power lift on farmall H
Posted by Boyd on July 20, 2004 at 14:27:16 from (208.186.57.65):
In Reply to: power lift on farmall H posted by Hank on July 20, 2004 at 12:26:45:
On the bottom of the tractor just in back of the hyd pump ( may be a plate with 2 0r 4 cap screws in , take that off and you will see a good size shaft with large cotter keys in it, pull keys out, slide collars toward the center of the shaft and let shaft slide down, (dont get under it while taking shaft out, it is heavy) might give you a bloody nose. You can run the tractor with no problem, as long as you want. Be sure and save the shaft, you may want put hyds back in.
Post a Followup
: Re: Re: power lift on farmall H
