Re: SMTA---TA Question
Posted by Hayfarmer on July 20, 2004 at 22:21:05 from (12.160.171.190):
In Reply to: SMTA---TA Question posted by ds on July 20, 2004 at 17:44:28:
The first step would be to make sure it is adjusted correctly. The adjustment is detailed and requires an owner's manuel or service manuel. If the TA slips in low range, stops when you shift the lever back, it is usually caused by the ramp and roller being bad. If it slips in the high side it is generally the ta clutch slipping. Since yours will not go into the low range my guess would be that the ta clutch plate is stuck or sticking. Perhaps it will owrk in 5th because ther is more pressue against it. There is a plate on top of the ta section, ahed of the belt pully. If you take the cover off you can look in on the ta clutch and may be able to see if that is the problem. Otherwise maybe if you try it under load and pull the lever back it might come loose. Of course when it does part of the lining may stay attached to whatever it is stuck to. I am not sure how much work you can do through the plate on top of the ta. The TA pressure plate is similar to the main clutch plate in that you can put some bolts in from the back to hold the plate under pressure, then remove the 3 bolts that hold it to the "flywheel or driven surface. The service manuel describes this procedure. If you can release the pressure plate you should be able to get the clutch plate loose. Let us know how it goes.
Home
| Forums
Today's Featured Article -
Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
