Re: H carburator and governor
Posted by Mag Man on July 21, 2004 at 09:41:05 from (64.12.116.14):
In Reply to: H carburator and governor posted by John Gallagher on July 21, 2004 at 09:25:33:
Yes there is a Kinda V shaped part in the carb that has to have the tang in the gov tube fit in side . sound like you put yours together at one side or the other of the V use a flash light to see when you put it back you may have to loosen the carb a little if you cant get it right in place. JON
Post a Followup
: Re: Re: H carburator and governor
