Re: H carburator and governor
Posted by Theman on July 21, 2004 at 10:34:19 from (65.248.77.5):
In Reply to: H carburator and governor posted by John Gallagher on July 21, 2004 at 09:25:33:
John, having to run with the choke closed and the engine racing are two separate problems. The carb float on my '47 H was set to low and I had to choke it like you have done to keep the engine running. Re-adjust the float level and make sure the needle valve isn't stuck.
The revving problem is probably what Mag Man covered in his post.
Post a Followup
: Re: Re: H carburator and governor
