Re: Grease fitting for pilot bearing
Posted by Chris Brown on July 21, 2004 at 19:50:32 from (209.206.208.56):
In Reply to: Grease fitting for pilot bearing posted by BB on July 21, 2004 at 19:39:41:
I don't know about the H, but I have seen pilot bushing grease fittings. It would be a grease passage drilled through from the outer edge of the flywheel to the center,and yes you have to turn the engine till it lines up. I never looked on my H to see if there was one.
Post a Followup
: Re: Re: Grease fitting for pilot bearing
