Re: paint ?
Posted by ugly in Tx on July 21, 2004 at 21:03:10 from (63.233.229.58):
In Reply to: paint ? posted by Dale L on July 21, 2004 at 16:19:24:
PPG has a urethane material called Polane, they can match the farmall color. it is a really good finish, it requires catalyst and a special reducer (thinner) but it is worth the money. finish is very scratch resistant and very durable. The exterior material is quite pricey, but if you want something to hold up, it's worth it. It is capable of heavy build up with just air flash of a few minutes. When it cures ( about 6 hours ) you can let a cigarette burn up on it and wipe the discoloration away with a wet rag. You may have to get your PPG man to call in to get the info because it is a specialty coating. you should not need clear coat. They do make a Polane clear coat tho.
Post a Followup
: Re: Re: paint ?
