Re: Re: paint ?
Posted by CNKS on July 22, 2004 at 07:37:46 from (207.178.96.212):
In Reply to: Re: paint ? posted by gauger on July 22, 2004 at 06:09:32:
Most acrylics are about the same as 2150. Example PPG Omni Acrylic enamel is 4:1 paint:reducer. With hardener it is 8:1:1 paint:reducer:hardener. You cut the reducer in half and add hardener. PPG Omni acrylic urethane is 4:1:1. The only paint I have ever seen that is reduced 1:1 is acrylic lacquer -- takes multiple coats, there is no longer a reason to use acrylic lacquer. PPG's products when used as the instructions say are not runny, a better word is flawless, unless there is a malfuction of the operator (me).
Post a Followup
: Re: Re: Re: paint ?
