Ignition switch or cable
Posted by daniel on July 23, 2004 at 16:57:32 from (24.75.99.162):
On my H My starter wont run when it is all hooked up. but if i take it off the tractor and bump it with jumper cables fromt he battery then it runs I have tight connections of the bsttery when it is on the tractor and hooked up. I put the test light on the chasis to the + on the battery and it shows power, from there to the switch(Hand press down on button to complete circuit to starter)sows power. WHen i press down on the switch nothing happens. I put the light on the other side of the switch and shows no power. So I took the wire off and power comes back. Should I replace the wire or the switch?
Sorry for the lengthy message!
Post a Followup
: Re: Ignition switch or cable
