Re: farmall m rings
Posted by El Toro on July 23, 2004 at 19:25:37 from (64.12.116.14):
In Reply to: farmall m rings posted by pedro on July 23, 2004 at 06:22:54:
Hi Pedro, Are these new sleeves and pistons that you're installing? There's a rule of thumb for determining ring gap. For every inch of piston
diameter you multiply by .003. On a Farmall M with a piston diameter of 3.875"X .003= .0116".
This is within the .010" to 020" limits stated in the IH manual.
I never knew where this rule came from, but it is very close to the clearances you need on your ring gaps. Good Luck, Hal
Post a Followup
: Re: Re: farmall m rings
