Re: wd-6 HAS A MISS SOMETIMES?????
Posted by Geoff NY on July 24, 2004 at 14:57:20 from (205.188.117.22):
In Reply to: wd-6 HAS A MISS SOMETIMES????? posted by jEFF on July 23, 2004 at 20:42:20:
You might want to warm it up and check the valve gap clearances. If all that work has been done the head has been off and possibly the valves wern't checked after break in. Also pull the screen (filter) on the side of the primary pump and make sure it is clean. Good luck, Geoff
Post a Followup
: Re: Re: wd-6 HAS A MISS SOMETIMES?????
