Re: Metal Fuel Line on A
Posted by Christopher S. Dunn on July 25, 2004 at 09:58:29 from (216.141.73.14):
In Reply to: Metal Fuel Line on A posted by Christopher S. Dunn on July 23, 2004 at 09:49:31:
Okay, thanks for the input. I have a fuel line with a rubber section in between the metal parts (like that when I got it, I put a new fuel hose section in it, though) and I gave that a healthy squeeze 2x and restarted. It ran for about 8 seconds and died. I repeated and she continued to run. I idled her down, put her in gear (no PTO) and started for the house. Immediately she stuttered and "bucked" under load. By fits and starts, I got the tractor back to the house and let her run there and played with the idle speed a bit (idles too high right now.) I let her run outside like that for about 20 minutes and no problems. The water temp seems okay, the tractor is running relatively smoothly. So I climb aboard, engage the PTO, put her in 2nd and take her for a big circle in the 'yard.' 2 seconds later and she's stuttering like before. I get her back to the place where I work on her and leave her in neutral and running. Still okay. Still running as I write this. I do have a new sediment bowl and I placed the fitting into the tank about 1/2" high instead of the original 1/4" to eliminate crud going down the tube, though I get that is not a guaranty. So, as I write this, I note the tractor is no longer running. I go out and try to start it and no go. I squeeze the line and then attempt again. I go, "Wonder if there is crud over the sediment bowl fitting into the tank?" I open the cap and put my lighter right over the hole... just kidding... I used my flashlight after I turned it on away from the tank (its a little `un) and I shined it down there over the hole. There was something there. From where I was standing, I decided to give the rubber fuel line section a squeeze to observe the goings on. Sure enough, the crud pops up out of the hole with some bubbles. I do it again and something else pops out, and then falls right back in. In the old line of work I was in, we'd call that a 'smoking gun.' So I am leaning toward emptying the tank, pulling the lines and cleaning them out with a brush, air or both. I have a job to complete and cannot afford to take several days to do the acetic/muriatic acid thing with the tank and let dry. Is there some other fluid (beyond gasoline) that I can flush the tank with, blow out, and then get started within a 24 hour period or should I just blow it out and not use a fluid of any kind? NOTE: This tank method I propose is intended to see me through this job and then I can do more long term methods... Thanks again for all your input (even when I don't like hearing it...) and I welcome further assistance in this matter. (my formal voice, sorry.) Christopher
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
