Farmall Tractors Discussion Board
Re: Casting code???
Posted by Phil Auten on November 03, 1999 at 19:52:49 from (206.175.72.226):
In Reply to: Casting code??? posted by Otis on November 03, 1999 at 19:06:34:
Otis,
Casting codes should be on all the major castings of the tractor. They look something like this:
@2.12.S@
Where the @'s look like screw heads (because they used screws to hold the code plates to the molds).
The letters started with H in 1938 and ran through T in 1950. U and W were used in 1951 (V was skipped), then X, Y and Z through 1954. They start again with A in 1955 through D in 1958. The first two numbers are the month and day, so 2.12.S would be Feb 12, 1949.
Phil
Post a Followup
: Re: Re: Casting code???
