Re: What do I do?
Posted by Randy SE-MN on July 28, 2004 at 13:50:44 from (206.9.216.55):
In Reply to: What do I do? posted by Matt on July 28, 2004 at 13:21:38:
Go purchase a reverse rotation drill bit, center punch the broken portion, set your drill to counter-clockwise and most times the broken bolt will walk itself right out.
Post a Followup
: Re: Re: What do I do?
