Re: 140 transmission leak
Posted by Bus Driver on July 28, 2004 at 15:37:58 from (66.226.35.207):
In Reply to: 140 transmission leak posted by WalJohn on July 28, 2004 at 14:12:01:
Have you checked for overfilling? The fill level plug is on the left side of the transmission partially hidden by the brake rod. If the tractor is stored outside, rain water can cause apparent overfilling. If it is overfull and is not from your action, I suggest draining and starting over with fresh, clean lube.
Post a Followup
: Re: Re: 140 transmission leak
