Farmall Tractors Discussion Board
Re: Farmall Regular oil leak
Posted by Paul Fox on November 04, 1999 at 15:05:28 from (204.176.212.3):
In Reply to: Farmall Regular oil leak posted by John F. on November 04, 1999 at 14:35:02:
I don't know if it's reasonable to try to draw parallels between a Regular and an F14, but just as general information:
My F14 does NOT have a gasket between the block and the flywheel housing. The rear main bearing does have an oil slinger and guard, with a felt seal that weeps some oil into the flywheel housing and then drips out the weep hole on the bottom.
If it's bad enough to be leaking by the block, you will probably have to pull the flywheel cover and check/replace the seal.
Post a Followup
: Re: Re: Farmall Regular oil leak
