Re: Air Cleaner oil cup rusted out on Farmall 100
Posted by Jim Becker on July 30, 2004 at 07:45:44 from (4.26.214.177):
In Reply to: Air Cleaner oil cup rusted out on Farmall 100 posted by Ramon from NC on July 29, 2004 at 08:38:23:
I fixed one with JB Weld. I cleaned it up and bead blasted the inside near the hole. Then spread a little bit of JB Weld on from the inside. Depending on the size of the hole, you may need to file a little off the outside after it cures.
Post a Followup
Subject:
