charging positve ground
Posted by chuck on July 30, 2004 at 23:38:35 from (24.236.170.254):
I have a 52 H that has positve ground. It seems that when it is running the needle for the discharge or charge stays in the discarged area a little. After starting a few times it seems I have to charge the battery back up. I have two questions. What can I check or do to make it charge? Also how do I charge the battery while it is in the tractor and hooked up. Do I put the red cable on the pos or the neg?
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
