Re: farmall h starter
Posted by rustyfarmall on August 01, 2004 at 10:33:52 from (216.248.75.157):
In Reply to: farmall h starter posted by scottc(va) on August 01, 2004 at 08:26:29:
Your starter button is wired correctly, the system is a positive ground, not negative ground as you are more familiar with. When using jumper cables to test the starter, connect the negative cable to the post on the starter, and the positive cable to the starter frame.
Actually, the starter should operate no matter how you made the connections. In other words, the starter doesn't care if it is negative ground or positive ground. You may want to remove the end plate from the starter and check out the condition of the brushes, they may be worn out.
Post a Followup
Subject:
