IH 384 - oil leak after changing engine oil....
Posted by BradleyB on August 01, 2004 at 11:16:17 from (66.61.106.59):
I changed the engine oil on my IH 384 tractor yesterday. After putting everything back together and cranking the motor, I discovered that it was leaking around the bottom of the oil filter canister. It is actually leaking around where the bolt screws up through the bottom of the oil filter canister. I have tightened the bolt up as tight as I can get it without possibly stripping the threads, but it is still leaking. The previous filter wasn't leaking at all and I carefully put everything back together exactly like it was before as far as i know. When I put it back together, I placed the small rubber gasket around the bolt and slid it down to the bottom of the oil filter canister. Next, I placed the spring down over the bolt and then placed the metal disc the holds the oil filter in place down over the bolt. Next comes the oil filter and then the metal disc that holds the top part of the oil filter in place. After putting all of this together, it is then screwed onto the oil filter housing on the side of the motor. After tightening the oil filter canister into the the oil filter housing and cranking the motor, there is a steady stream of oil coming out of the bottom of the oil filter canister. I took it all back off and tried to make sure that bottom rubber gasket was pressed onto the bottom of the oil filter canister and as far as I can tell, it was. I then put everything back together and discovered that it was still leaking. Does anyone have any suggestions on what I may be doing wrong or what I may have assembled backwards. Also, do you know if there is some type of a conversion made that will allow you to use a regular screw on oil filter like the ones that fit onto diesel cars or trucks. Thanks for any help in this matter.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
