Re: What do I do?
Posted by LJ on August 01, 2004 at 20:56:40 from (216.78.15.72):
In Reply to: What do I do? posted by Matt on July 28, 2004 at 13:21:38:
I have taken out a lot of broken bolts
If you broke the bolt screwing it in & it turns freely till the head hit the grille & over torque it the bolt & snapped off the head
most of the time they come out easy
If you the bolt was hard to turn from the start & had to wrench it down or hit bottom of the hole
and twisted it off LAST thing you want to do is use a EZ out when the EZOut brakes off thin you have Big problens EZOut is hard & don'drill good
best way to get it out is to drill it it out
& pick the pices out & run a tap to chase the threads
Post a Followup
Subject:
