Re: Farmall H puller tranny problem
Posted by lee on August 02, 2004 at 11:24:34 from (24.24.95.246):
In Reply to: Farmall H puller tranny problem posted by ChadS on August 02, 2004 at 09:45:42:
Replacing the gears and shafts is going to probably fix a lot of it as worn gears is probably where it started. You'll also have to replace all the worn parts in the shift rail mechanism. Anything that's worn from having that shift handle strapped down will need to be replaced. Replace the detent springs with new ones.
Post a Followup
Subject:
