Re: Are points my problem?
Posted by john *.?-!.* cub owner on August 02, 2004 at 16:59:53 from (66.112.43.130):
In Reply to: Are points my problem? posted by Jeff on August 02, 2004 at 16:53:46:
Did you also change the condenser? A bad condenser will cause the points to burn, and also cause a weak spark. A magneto coil beginning to break down will also cause a weak spark. The spark should be a good blue color, if it's weak or yellow the coil may be going bad. If this is a work rather than a show tractor, it's easy to convert to a battery ignition coil and still let the mag operate the points nad rotor.
Post a Followup
Subject:
