Re: H not charging, how do i check generator out?
Posted by Bob M on August 03, 2004 at 09:12:48 from (165.170.128.66):
In Reply to: Re: H not charging, how do i check generator out? posted by Randy on August 03, 2004 at 08:32:15:
If your generator failed due to an internal short in the armature, simply replacing the generator should solve your problem. (This happened to one of mine this spring...) However bad regulator can also quickly fry a good generator.
Good practice is to install a new regulator when you replace any generator. Consider it $40 well spent!
Post a Followup
Subject:
