Re: M Operating Temperature
Posted by Gringo on August 03, 2004 at 16:49:31 from (148.63.132.164):
In Reply to: M Operating Temperature posted by Farmall Don on August 03, 2004 at 14:38:29:
Don,
Stick a thermometer in the radiator when she shows hot.
If the gauge is up in the red that temp should show about a 230 to 250 degree reading or higher.
Anything less and you've got a bad gauge (if the water is circulating).
Allan
Post a Followup
Subject:
