Re: M Operating Temperature
Posted by Ken K on August 04, 2004 at 13:38:16 from (67.200.32.61):
In Reply to: Re: M Operating Temperature posted by Farmall Don on August 03, 2004 at 16:12:31:
Feal the hoses for heat on both sides of the block heater. One side should be warm and the other cold when the tractor is running. There is a valve in the heater to keep the water from circulating in the wrong diriction. If this valve is not working properly, this may be your problem. Just a thought.
Post a Followup
Subject:
