Re: H not charging, how do i check generator out?
Posted by Milan on August 04, 2004 at 16:20:43 from (216.234.101.103):
In Reply to: H not charging, how do i check generator out? posted by Randy on August 02, 2004 at 10:35:37:
I had the same problem with my H, and Super C.
Take the brush cover strap off the generator, get a piece of emery cloth about an inch wide and clean the snot out of the armature, should be shiny copper. You will have to lift the brushes up off the armature to snake the emery paper around the shaft. You don't even have to take the generator off, removing the hood gives you more room to work though. Rotate the generator by hand (ignition off) to clean all the way around it.
I had absolutely no charge before I did this, and now I'm getting up to 30 amps on high charge, and 10 amps on low charge at high rpm's.
Good Luck
Post a Followup
Subject:
