Re: Farmall 450 steer shaft problems
Posted by Joe Evans on August 06, 2004 at 05:52:06 from (209.41.233.80):
In Reply to: Re: Farmall 450 steer shaft problems posted by lee on August 05, 2004 at 21:15:03:
Lee: to find out what I was dealing with, I miked the end of the steering shaft. It was bunged-up, corroded and a bit out of round, but the average reading I got was around .850, so I concluded the shaft was .875 at one time.
The existing threads were of poor quality and seemed to be 20 threads per inch according to a guage I had. Is there a 7/8-20 UNEF thread? With nothing to lose, I first attempted to rethread over the very fine thread with a 7/8-14 thinking that this will bite deep into the existing threads and form (rather crude admittedly) new threads. There wasn't enough material there, but the 7/8-9 did the trick. It's not a perfect fix, but usable.
I re-bushed the hole where the shaft enters the dash casting--whatever was there originally was gone. A 7/8 ID x 1 OD bronze flange bushing fixed this slicker than snot on a pump handle. I had to polish the shaft's OD a bit at the area where the bushing was going to go so that the bushing would slip into place over the shaft. This confirmed the shaft's OD as 7/8".
Post a Followup
Subject:
