cutting out 154
Posted by kevin on August 07, 2004 at 10:41:51 from (168.215.108.44):
I have a cub lowboy 154 that cuts out under load. when it cuts out if I kickout the mowerdeck it will run fine but as soon as I put it under load it will start to cutout again. I have put everything new in it. Points plugs,wires coil and cleaned the whole fuel system and it didnt help a bit. I am baffled. Can anyone help please.
Post a Followup
Subject:
