Re: Farmall A Pouring water
Posted by Phlogiston on August 07, 2004 at 16:34:29 from (65.129.72.20):
In Reply to: Farmall A Pouring water posted by Matt on August 07, 2004 at 11:59:39:
Farmall A's have thermosyphon cooling systems. If you have it over filled it will get rid of the extra until it finds its own level. Read your owners manual, it will explain in there. If you don't have one, get one.
Phlogiston
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
