Re: Question for everyone...
Posted by Bob on August 08, 2004 at 13:05:23 from (66.163.134.177):
In Reply to: Question for everyone... posted by ffolkes on August 08, 2004 at 11:05:14:
The lever on the governor and the lever on the other side of the engine are NOT directly connected inside the governor... each lever is hooked to the opposite end of the (internal) governor spring, so a certain amount of free travel between the two levers is normal.
If the governor is responsive, it's probably OK, but if the bushings are REALLY LOOSE. governor response will suffer, and it's time for a rebuild.
The thrust bearing in these governors wears, and if it fails, the governor fork will be damaged.
Post a Followup
Subject:
