Re: Farmall H Problem
Posted by Michael Soldan on August 12, 2004 at 15:25:33 from (216.46.130.24):
In Reply to: Farmall H Problem posted by J.C on August 11, 2004 at 18:12:32:
J.C. how did you check the spark? If you held the wire off the plug you can get a good blue flash but that doesn't mean the plug will fire properly. My H was running on three this spring and I put new D21 Champions in and it has been fine ever since. As was suggested , check the distributor cap, check the wire for resistance then you need to dig deeper if this hasn't helped...ie) valve adjustment, stuck valve, manifold intake leak etc.......Mike in Exeter Ontario
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
