Re: product search
Posted by Nebraska Cowman on August 14, 2004 at 03:52:45 from (65.162.146.189):
In Reply to: product search posted by jim w on August 13, 2004 at 07:58:06:
You can fix it but it is tricky. When you start to solder the expansion of the air will tend to bolw the solder out of the crack. When you get done check for leaks by dipping in warm water. If you still have leaks the warm water will heat and expand the air inside and blow bubbles. I have even drilled a small hole to drain out the gas that is inside, then solder up the hole last.
Post a Followup
Subject:
