Farmall Tractors Discussion Board
Re: A electrical
Posted by ltf in nc on November 07, 1999 at 06:43:07 from (206.228.213.236):
In Reply to: A electrical posted by Chuck on November 07, 1999 at 06:33:55:
You know more than you realize. By removing the cable while the engine was running and the engine died you have identified that the alternator, as it is mounted on your tractor, is NOT charging. After having it tested, you will know if the problem is from the alternator or from the "setup" on the 12 volt conversion. Post your results and good luck.
Post a Followup
: Re: Re: A electrical
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
