Re: 504 clutch problem
Posted by captaink on August 16, 2004 at 06:30:57 from (66.115.212.249):
In Reply to: 504 clutch problem posted by Nellie on August 15, 2004 at 04:30:06:
The others are correct, the TA clutch needs to be adjusted every time the main clutch is adjusted. Also, when you replaced the pressure plate on the clutch did you check the finger heigth? If they are set incorrectly, it can mess up the location of the clutch rod adjustment clevis.
Post a Followup
Subject:
