Re: Power-steering on 560
Posted by Will J on August 16, 2004 at 14:06:43 from (24.154.95.214):
In Reply to: Power-steering on 560 posted by Jason on August 16, 2004 at 10:20:06:
I had a similar problem on my 460. Follow the hydraulic lines to under the radiator to a small
block. That is the steering cylinder. It unbolts from the frame and has a lever which goes up into the housing.
When it's off take it apart and make sure the internal cylinder isn't gummed up and that the lever is actually on the pin. Make sure that you have the little O rings for the hydraulic lines before starting though. They will probably fall apart when you disconnect the lines.
My lever had worked itself off the pin and the steering wasn't working at all.
Post a Followup
Subject:
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
