Re: TD9 engine oil
Posted by Geoff NY on August 17, 2004 at 16:28:41 from (24.190.232.232):
In Reply to: TD9 engine oil posted by Loren P. on August 17, 2004 at 09:15:34:
I've had this same problem on 3 out of 4 of my diesels. The seal on the shaft is leaking and letting fuel into the engine, YES. Also the seal on the primary pump is letting fuel past into the sump of the injector pump. If you don't fix both seals you will still have a problem. If you are interested I can give you a name of a good place to get the parts. I also have the fuel injection parts manual if you need #s. E-mail Hallocktractor@aol.com
Post a Followup
Subject:
