Re: clutch adjustment on C Farmall
Posted by CNKS on August 18, 2004 at 18:11:56 from (207.178.99.5):
In Reply to: clutch adjustment on C Farmall posted by wildman on August 18, 2004 at 18:05:26:
Factory spec is 1 7/16 inches from the pedal to transmission cover. Gears will always grind if you don't wait for them to stop turning after you push in the clutch. This can be minimized if they are shifted at idle. There should be only minimal grinding when shifting with the tractor moving, unless you are shifting from 4th to a lower gear. The gears are not syncronized.
Post a Followup
Subject:
