Re: Crank case oil for C Farmall
Posted by captaink on August 19, 2004 at 07:23:59 from (66.115.212.249):
In Reply to: Crank case oil for C Farmall posted by wildman on August 19, 2004 at 05:46:08:
As rustyfarmall indicates, oil like you would use in any other vehicle. I recommend for temps constantly below 32 degrees 5W-20. If it never gets below zero or higher than 70 I suggest 10W-30, and if it is constantly above 50, then go with 15-40. My nickel’s worth…
Post a Followup
Subject:
