Re: knock in front-end of M
Posted by Farmer Bob on August 19, 2004 at 15:51:52 from (67.5.119.40):
In Reply to: knock in front-end of M posted by Big Sal on August 19, 2004 at 15:11:16:
Have you checked for play top to bottom/front to back with the front end jacked up off the ground? It coulde also be a loose mounting bolt on the rims that fasten the rim to the hub. If these all check out okay, remove the hub cap on each side and the large spindle nut and check the bearings and races. You could have a cracked race or a bad bearing or both.
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
